510
ENABLE AND disable the soem columns in a row on checking the checkbox column cell
Hi ,
I have 30 columns in a grid.
Based on some conditions I need to disable  some cell disabled  and some cells editable in a row.
In a row  I do have check box column. If I uncheck the check box then entire row can be edited. If it is checked then some cells will be disabled and some cells will be enabled.
Please need help on this.
