I want to set the Grid using Code behind. (nothing to use Grid Designer, *.cs file).
Setting operations like blow function.
1. Setting Column
1.1 Set the Column Head to Multi-Lines (2~3 Level)
1.1 Set the Column (Title/Width/Datatype/Fixed Columns)
2. Data Binding to Grid
2.1 if i set Multi-Columns Head, How can i set Data to Grid Cells.
Would you Help me the example or sample?
Hello Boris
thank you for your assistance. i solve my issue.
Hello ecogear,
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
Here is a code sample which I believe could help you:
noCol.Header.VisiblePosition = 0; noCol.RowLayoutColumnInfo.OriginX = 0; noCol.RowLayoutColumnInfo.OriginY = 0; noCol.RowLayoutColumnInfo.PreferredLabelSize = new System.Drawing.Size(0, 48); noCol.RowLayoutColumnInfo.SpanX = 2; noCol.RowLayoutColumnInfo.SpanY = 4; userNameCol.Header.VisiblePosition = 1; userNameCol.RowLayoutColumnInfo.OriginX = 2; userNameCol.RowLayoutColumnInfo.OriginY = 0; userNameCol.RowLayoutColumnInfo.PreferredCellSize = new System.Drawing.Size(196, 0); userNameCol.RowLayoutColumnInfo.SpanX = 4; userNameCol.RowLayoutColumnInfo.SpanY = 2; ageCol.Header.VisiblePosition = 2; ageCol.RowLayoutColumnInfo.OriginX = 2; ageCol.RowLayoutColumnInfo.OriginY = 2; ageCol.RowLayoutColumnInfo.SpanX = 2; ageCol.RowLayoutColumnInfo.SpanY = 2; sexCol.Header.VisiblePosition = 3; sexCol.RowLayoutColumnInfo.OriginX = 4; sexCol.RowLayoutColumnInfo.OriginY = 2; sexCol.RowLayoutColumnInfo.SpanX = 2; sexCol.RowLayoutColumnInfo.SpanY = 2; deptCol.Header.VisiblePosition = 4; deptCol.RowLayoutColumnInfo.OriginX = 6; deptCol.RowLayoutColumnInfo.OriginY = 0; deptCol.RowLayoutColumnInfo.PreferredLabelSize = new System.Drawing.Size(0, 48); deptCol.RowLayoutColumnInfo.SpanX = 2; deptCol.RowLayoutColumnInfo.SpanY = 4; ultraGridBand1.Columns.AddRange(new object[] { noCol, userNameCol, ageCol, sexCol, deptCol}); ultraGridBand1.RowLayoutStyle = Infragistics.Win.UltraWinGrid.RowLayoutStyle.ColumnLayout;
If you are not able to implement this code in your project please let me know, I will provide a sample for you.
Thanks for your help.
I see Your Example.
I think My Question is poor, then additionally I want to know the below things.
Can I set the Grid (like attached File) by Only Code Behind?
I tried to wrap up a small sample for you, to demonstrate the desired requirements. I am not sure only for the last requirement. Could you please review my sample and let me know if I misunderstood you.
