I had the following code in the initialize row event of the ultragrid
if (e.Row.Cells.Exists("UpdateMap")) { e.Row.Cells["UpdateMap"].Value = .......Resources.search; }
This would add a search image to UpdateMap column of each row in grid. [search is a png file added to the resources folder of the project.] Now when I bind the grid with a large datatable , the program exits with outofmemory exception.I presume this could be because a new image object is created for each row, thereby creating many instances of the same image.
A similar issue was reported earlier where Mike had proposed to create a set of Appearance objects to do this efficiently.
After going through the guide ,I modified the above code and have it in two events now with the appearance object
In InitializeLayout
if (!e.Layout.Appearances.Exists("SearchImage")) { Infragistics.Win.Appearance searchImage = e.Layout.Appearances.Add("SearchImage"); searchImage.Image = .......Resources.search; }
And in InitializeRow
if (e.Row.Cells.Exists("UpdateMap")) { e.Row.Cells["UpdateMap"].Appearance = Grid.DisplayLayout.Appearances["SearchImage"]; }
UpdateMap column is of image type, but the grid now displays a blank cell with no image at all.What is that I am missing here?
Rajesh
Awesome!!..That worked for me..Thanks
Hello Rajesh,
Could you please try the 'ImageBackground' instead of the 'Image' property, like this:
searchImage.ImageBackground = .......Resources.search;
I will be waiting for your feedback.
