I am trying to display negative numbers with a parenthesis around the number. When I use the UltraMaskEdit I can only get it to display a minus sign. I switched the control to a UltraNumericEditor and my only option for data type is an int or a double. I have decimal data will the UltraNumericEditor affect precision?
Thank you
Chris
Chris,
Hot fixes are cummulative, so yes they would contain all previous fixes. As for specific installation notes, these may be included with the installer that you download from the main website, though I am not certain; you could either download the hotfix to check, or you could contact developer support if you are hesitant about installing the hotfix. Basically, the installer will update your existing assemblies with the newer versions, so you should be good to continue working immediately after installation.
-Matt
Thank you Matt. If I install the latest Hot Fix will that contain all previous hot fixes? I could not find any user installation docs on the hot fixes available. Are those in a different area?
Thank you for your assistance.
NumericType.Decimal was added to 8.1 in a hotfix, which I believe is the latest hotfix that was recently released.
