605
UltraDropDown In WinGrid
Here is what I am trying to accomplish.
I have an ultrawingrid and clicking on one of the columns should display a ultradropdown.
I have done the following in the wingrid (dgItems)
 private void dgItems_AfterCellActivate(object sender, System.EventArgs e)
     UltraGridCell activeCell = ((TWMDataGrid)sender).ActiveCell;
      if (activeCell == null || activeCell.GetType() != typeof(UltraGridCell)) return;
      if (activeCell.Column.Key == "ItemCode")
       BindItemsDropDown();
The above code binds a list to the Ultradropdown, when the column ItemCode is clicked.
And in the following method ..
private void dgItems_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
e.Layout.Bands[0].Columns["ItemCode"].ValueList = this.cmbItems;
where cmbItems is the Ultradrodown.
What I currently see  when I run this application is that when I click on the ItemCode coulmn in the Ultragrid, the dropdown shows up in a different place rather than right below the column.
And the Ultrdropdown, once it appears does not seem to be disappear, when I click else where on the form. It remains visible.
I would also like to add a scroll bar to the ultradropdown control.
And i also noticed that the Ultrawingrid, UltraDropdown are all placed in a Panel, which is then added to the Controls collection.  Could this be the cause of the problem ?
Ashwin
  • 605
    Verified Answer
    Phew ! .... finally figured out that the property of the object being bound to the grid did not have a setter property.
    And hence was not able to display the drop down !! .. I could not have imagined this even in my wildest dreams !!
  • 605
    I also have to mention that the UltraDrodown.Visible property is set to false on the designer. And when I bind the dropdown, I set the visible property to true explicitly.
    When I don't set the visible property to true while binding the drop down, I dont even see the ultradropdown when I click on the ItemCode coulmn in the UltraWinGrid.
