Hi guys
I have a valid dataset with 3 tables that im wanting to display in my ultrawingrid. The tables are related.
Can someone please explain step for step on how to get my 3 tables to appear im my grid?
i can populate a grid with 1 table no problem.
do i have to use the ultra datasource to get this to work? if so how?
Hi
think this is a problem related to my dataset... think the third relation is not valid... thats why the schema error is happening....
thanks for the support on this oone tho...
Hello Burmo,
I`m not sure what you mean with :
Burmo said:I just extra info.... i was geting an error of tables in grid schema must match of datasource...???
Did you take a look at the attached sample ? Please provide more details about your issue.
Regards
Hello Birmo,
One possible way to achieve desired behavior could be if you set Relation between tables in your DataSet. For example:
DataSet ds = new DataSet(); DataTable dt = new DataTable(); dt.Columns.Add("ID", typeof(int)); dt.Columns.Add("Col 1", typeof(string)); dt.Columns.Add("Col 2", typeof(string)); dt.Columns.Add("Col 3", typeof(int)); DataTable dt2 = new DataTable(); dt2.Columns.Add("PID", typeof(int)); dt2.Columns.Add("Col 11", typeof(string)); dt2.Columns.Add("Col 22", typeof(string)); dt2.Columns.Add("Col 33", typeof(int)); dt2.Columns.Add("Col 44", typeof(int)); ds.Tables.Add(dt); ds.Tables.Add(dt2); DataRelation dr = new DataRelation("DR", dt.Columns["ID"], dt2.Columns["PID"], true); ds.Relations.Add(dr); ultraGrid1.DataSource = ds;
ds.Tables.Add(dt);
ds.Tables.Add(dt2);
Please take a look at the attached sample for more details and let me know if you have any questions.
Regards ...
