605
RowSelected Event of UltraDropDown Not working :(
I have an Ultrawingrid and couple of coulmns in the windgrid display a UltraDrop down when clicked on it. Now once the drop down displays, I would like to set a couple of columns on the UltraGrid when the user choses a a row in the UltraDropdown.
To make this work I have the follwoing code in the constructor
cmbItems.RowSelected +=
new RowSelectedEventHandler(cmbItems_RowSelected);
And in the method I do the following
 private void cmbItems_RowSelected(object sender, Infragistics.Win.UltraWinGrid.RowSelectedEventArgs e)
            if (cmbItems.SelectedRow != null)
                OrderRepositoryRequest ORR = (OrderRepositoryRequest)dgItems.ActiveRow.ListObject;
                Item item = (Item)e.Row.ListObject;
                if (item != null && item.ItemCode.ToString() != ORR.ItemCode)
                    dgItems.ActiveRow.Cells["ItemCode"].Value = item.ItemCode;
                    dgItems.ActiveRow.Cells["ItemName"].Value = item.Name;
                    dgItems.ActiveRow.Cells["Vintage"].Value = item.Vintage;
                    dgItems.ActiveRow.Cells["UnitPerCase"].Value = item.UnitsCase;
this even is supposed to fire when the user selects a row from the Dropdown list that gets displayed. But for whatever reason this method seems to be firing as soon as I click on the column in the Grid to display the drop down.
Any help would be greatly appreaciated !
THanks,
Ashwin
