914
key property is not supporting case-sensitive strings
Just discovered a problem after using this tree control for year. The key property appears to be case-insensitive now! The getnodebykey() API is returning the node assigned with a key of " B S H B" when passing a parameter of " B S H b". The docmentation does not say anyytthing about the key property being a case-insensitive string; only that the key must be unique! I need a very quick fix for this.
