255
Selected Row is changed when grid is refreshed
Is there a way to override the selected row being reset after its datasource is refreshed? I currently have the datasource to the grid set to refresh every 10 seconds, and I notice with this code when I start clicking through the messageboxes eventually they will be empty because the selected row has changed back to the top. I'm using the messagebox to test getting values from the row.
    Private Sub dgvUD01_ClickCellButton(ByVal sender As Object, ByVal e As CellEventArgs)
        'Dim rootRow As UltraGridGroupByRow = dgvCNCReview.Rows(0)
        If e.Cell.Column.Key = "make" Then
            For i As Integer = 0 To dgvCNCReview.DisplayLayout.Bands(0).Columns.Count - 1
                If dgvCNCReview.DisplayLayout.Rows(e.Cell.Row.Index).Cells(i).Column.IsVisibleInLayout And (dgvCNCReview.DisplayLayout.Rows(e.Cell.Row.Index).Cells(i).Column.Key <> "make" And _
                 dgvCNCReview.DisplayLayout.Rows(e.Cell.Row.Index).Cells(i).Column.Key <> "buy") Then
                    EpiMessageBox.Show(dgvCNCReview.DisplayLayout.Rows(e.Cell.Row.Index).Cells(i).Text.ToString)
                End If
            Next
        ElseIf e.Cell.Column.Key = "buy" Then
                'Dim _cell As UltraGridCell = dgvCNCReview.DisplayLayout.Rows(e.Cell.Row.Index).Cells(i)
                    'EpiMessageBox.Show(dgvUD01.DisplayLayout.Bands(aCell.Band.Index).Columns(i).ToString)
                End If
            Next
        End If
    End Sub
Thanks for any help,
Ted
