450
Need help in arranging Columns in a Multiband Grid
I have a grid which has 4 bands and the columns in band[3] are not arranged in order as in its parent bands. My primary requirement is to arrange the Band[3] columns.
This is a part of "Export to Excel" code. The grids are already displayed in the form.
I have tried the below approach -
private UltraGrid rearrangeCol(UltraGrid grid)
            int bandCount = grid.DisplayLayout.Bands.Count;
            int band = 0;
            List<String> colPos = new List<string>();
            for (int i = grid.DisplayLayout.Bands[band].Columns["EndurEndInv"].Index; i < grid.DisplayLayout.Bands[band].Columns.Count; i++)
                colPos.Add(grid.DisplayLayout.Bands[band].Columns[i].Key);
            band++;
            while (band < bandCount)
                int initialColPos = grid.DisplayLayout.Bands[band].Columns["EndurEndInv"].Index;
                for (int i = initialColPos, j = 0; i < grid.DisplayLayout.Bands[band].Columns.Count && j < colPos.Count; i++, j++)
                    if(!grid.DisplayLayout.Bands[band].Columns[i].Key.Equals(colPos[j], StringComparison.InvariantCulture))
                        grid.DisplayLayout.Bands[band].Override.AllowColSwapping = Infragistics.Win.UltraWinGrid.AllowColSwapping.WithinBand;
                        int xcngPos = grid.DisplayLayout.Bands[band].Columns[colPos[j]].Index;
                        grid.DisplayLayout.Bands[band].Columns.Insert(i, "Temp");
                        grid.DisplayLayout.Bands[band].Columns[xcngPos + 1].Swap(grid.DisplayLayout.Bands[band].Columns[i]);
                        grid.DisplayLayout.Bands[band].Columns.Remove("Temp");
                        grid.DisplayLayout.Bands[band].Override.AllowColSwapping = Infragistics.Win.UltraWinGrid.AllowColSwapping.Default;
                    else
                        continue;
                band++;
            return grid;
Actually, nothing happens when I use SWAP, the keys, index remains same.
Is there any better approach?
