170
Auto-suggestion control with columns, word wrapping and symbols highlighting
Hi Guys,
I need to implement a control that I've described in subject.
For this purpose I've chosen UltraCombo. The problem is that when I set column style to ColumnStyle.FormattedText for highlighting inputed symbols, code for word wrapping such as
private void ultraCombo1_InitializeLayout(object sender, InitializeLayoutEventArgs e)
            e.Layout.Override.CellMultiLine = DefaultableBoolean.True;
             e.Layout.Bands[0].Override.RowSizing = RowSizing.AutoFree
or
            e.Layout.Bands[0].Columns["My Column"].CellMultiLine = DefaultableBoolean.True;
doesn't work
but
            e.Layout.PerformAutoResizeColumns(false, PerformAutoSizeType.AllRowsInBand);
still works and I can get autoresizing for my columns but I need word wrapping and can not understand why it doesn't work when I set ColumnStyle.FormattedText. When this param was default, everything was fine and word wrapping works perfect.
Also I'm interesting why when we set AutoCompleteMode as Suggest and AutoSuggestFilterMode as Contains for UltraComboEditor, we take highlighting symbols in auto-suggested rows and if we set same properties for UltraCombo, we don't take this feature. Is it possible to do for UltraCombo. If it it, the first question won't be valid.
Hope to take at least answer for one my question, so I could be able to implement auto-suggest control with word wrapping and columns.
Thanks in advance,
Eugenij.
