I'm writing a windows forms application with an ultragrid.
For layout reasons I'm using the dock property. When I put this property on none (from the ultragrid) the scrollbars are displayed.
When I put this property on fill the scrollbars are gone.
Does anyone know how I can fix this?
I've added a dummy project which has the problem. Also an excel file is added to the rar-file. To see the problem copy the data in the excelfile,
then open the application and press the 'button1' - button to copy the data. You will see that the scrollbars aren't there.
Hello Gert,
Let us discuss this in the following forum thread:
http://ko.infragistics.com/community/forums/t/71655.aspx.
