445
Exception when Grid is drawn with DataSource
Hello Team Infragistics,
I recently messed around with our companys way to use the UltraWinGrid.
In the past we did everything sequential...which is stupid as we provide a very bad user experience when using our software.
For example, we got a DataSource from our MSSQL Database which had about 3k entries and was retrieved via a pretty confusing (and tehrefore slow) view on the datbase. So, this would lock up the whole software and once the complete data was retrieved the UltraWinGrids DataSource was filled.
I changed this a little and am now using a delegate to get the DataSource in another thread. Once the thread is done I retrieve the data and assign it to the DataSource as usual.
Here is a small snippet on how we fill the DataSource:
    Me.m_Grid.BeginUpdate()
    Me.m_Grid.SuspendRowSynchronization()
    Me.m_Grid.DataSource = m_AsyncDataSource
    Me.m_Grid.ResumeRowSynchronization()
    Me.m_Grid.EndUpdate()
Now, what happens with my asynchronus attempt is that I get an exception when I
resize the software window while the DataSource is assigned.
I tried searching for the problem....but it seems to be a inner exception which I can't really solve.
Here's the exception:
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
   bei Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   bei Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   bei Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   bei Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   bei Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   bei Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   bei Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   bei Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   bei System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   bei System.Windows.Forms.Control.WmPaint(Message& m)
   bei System.Windows.Forms.Control.WndProc(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Is there anything I missed?
I hope you can help me out here
TL;DR
1. Have a UltraWinGrid filled with a DataSource thatwas retrieved asynchronus
2. Resize the Program (and therefore the drawn area of the grid) while the DataSource of the Grid is filled and get above exception
I hope you can help me out here.
Thanks in advance
