http://msdn.microsoft.com/en-us/library/system.windows.forms.combobox.sorted.aspx
With MS Combo I can first sort existing items with Sorted = True then turn Sorted = False and add any other item to the top or bottom of the list without further affecting the sort.
With UltraComboEditor I can't replicate turning on/off sorting to get the same functionality. Setting the SortStyle to None will put the display back to unsorted.
SortStyle = ValueListSortStyle.Ascending
Hello ,
As far as I understand you was able to solve your issue based on my suggestion.
Have you tried simply leave the SortStyle set to Ascending or Descending and adding new items? I might be wrong, but I thought the sorting is a one-time thing and that the ValueList will not sort any new items you add to the list.
If I am wrong, then you might want to consider trying the same thing with UltraCombo. I am pretty sure that UltraCombo works that way - new items are not automatically sorted when you add them to the list.
12.1.20121.1001 I got it to work with this
Adding items
cbo.SortStyle = ValueListSortStyle.Ascending cbo.SortStyle = ValueListSortStyle.None
Add new item on top unsorted
Previously this will not work: the result was unsorted for the (Add Items section)
So yes, sorting is a one-time thing. The description could be made more clearer since it just says setting the SortStyle.
Add Items
Add new item on top
I have tested your scenario with Infragistics 12.1 service release 2038 (the latest service release). So when I set SortStyle of UltraCombo to None I am getting the same behavior as ComboBox. In the attached zip you will find sample and a video of my test.
Please let me know if you have any further questions or if I am missing something.
