Windows form. IG version upgrade from 11.3 to 12.1 Get warning error on compile. Can't open form with infragistics.win.ultrawinschedule.calendaecombo.databuttonscollection.add in the designer. Get error Method infragistics.win.ultrawinschedule.calendaecombo.databuttonscollection.add not found.
Upgrade was done via the version upgrade utility.
VS2010. Windows 7.
Hello Rookertrusted,
Thank you for your feedback.
If you need any assistance with this matter please do not hesitate to contact us.
I found that it was a reference issue.
rookertrusted wrote the following post at 07-23-2012 6:25 PM:
Windows form. IG version upgrade from 11.3 to 12.1 Get warning error on compile. Can't open form with infragistics.win.ultrawinschedule.calendarcombo.datebuttonscollection.add in the designer. Get error Method infragistics.win.ultrawinschedule.calendarcombo.datebuttonscollection.add not found.
Corrected the misspelling above. This is the error.
