30
DropdownEditorButton's Control on multiple monitors displays on primary monitor only
I have an application in which I use an UltraFormattedTextBox to do some input. I also have a dropdown added to the textbox for item selection from a pre-defined list. It all works neat - except when I'm resizing the form so that it spans two monitors, the dropdown control stays on my primary screen and doesn't expand to the other. (See attached images, those will make it clear.) Is there anything I can set to modify this behavior or that's just the way the control works?
One screen
Two screens
(NetAdvantage for winforms, 9.2)
