I have a column that has values that can be different formats;
1 / 1.0 / $1.00 / 7.65%
The grid is for displaying the data, no editing.
How can i format the text values to what I want? I dont seem to be able to figure out the correct formating string.
Heres what I have atm, works on the whole column :), not the cell itself.
uwGrid_RptResult_Prt1_InitializeRow
If (e.Row.Cells("Category").Text.IndexOf("Percentage") > -1) Then
e.Row.Appearance.BackColor = System.Drawing.Color.FromName("Lime") ' just so I can see I am in area I should be.
e.Row.Cells("Category: Result").Column.Format = "#0.##%" ' ok this does somethign but not sure what! the cell should be displaying 7.65% but i get 700%!
End If
Any help would be most appreciated on this.
Deasun
Yes, sorry i couldnt get back sooner. Vacation.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
It seems to me that you are trying to format each cell in the column with a different string, is that right? I believe that the format from your first post is not working because of the percent(%) sign. Do these formats in your last post work fine for you?
This is what I came up with:
for the % cells:
e.Row.Cells("Category: Result").Value = String.Format(System.String.Format("{0:F2}", e.Row.Cells("Category: Result").Value))
For the decimal cells:
Dim intValueIs As Integer = Convert.ToDecimal(e.Row.Cells("Category: Result").Value)
e.Row.Cells("Category: Result").Value = intValueIs
