340
Problem with resetting Back color of a cell after exiting edit mode
I try to reset the BackColor of a cell back to Color.White when it exit edit mode. FOr example, when the cell is activated I set a new color and when it is deactivated I want to set it to white, but it is not working. I have done all these things in the even, but it does not change the back color of the cell, except it works for the first cell of the row. I am using version 11.2.
UltraGridCell prevCell = null;   //the previous cell
void BAGridDataEntry_AfterEnterEditMode(object sender, EventArgs e)
 if (this.ActiveCell.Column.CellMultiLine == DefaultableBoolean.True)
this.ActiveCell.ActiveAppearance.BackColor = System.Drawing.Color.LightYellow;
 else
this.ActiveCell.ActiveAppearance.BackColor = System.Drawing.Color.Ivory;
 prevCell = this.ActiveCell;
 void BAGridDataEntry_AfterExitEditMode(object sender, EventArgs e)
 if (prevCell != null)
 this.ActiveCell.Appearance.ResetBackColor();
this.ActiveCell.Appearance.BackColorDisabled = System.Drawing.Color.White;
 prevCell.Appearance.ResetBackColor();
prevCell.Appearance.BackColorDisabled = System.Drawing.Color.White;
          prevCell.Appearance.BackColor = System.Drawing.Color.White;
 prevCell.ActiveAppearance.BackColor = System.Drawing.Color.White;
prevCell.Appearance.BackColor2 = System.Drawing.Color.White;
prevCell.ActiveAppearance.BackColor2 = System.Drawing.Color.White;
