530
Is it Possible to read the Recurrence Pattern
Hi All,
I have one Situation, where I can Sync my Infragisitic Calendar to Outlook, if it is a Single Appointment then there is No Problem, but when i create a Recurring Appointment i also need to Create a Recurring Appointment in Outlook Calendar. this can be only Possible if i can read the Recurrence Pattern from the Infragistic recurrence Dialog, as far as i know, all the Recurring Property is Saved in Byte format on ALLPROPERTIESMEMBER , can we have any method so that we can read from that byte and can know , is it daily or weekly, or monthly etc.
  • 53790
    Hello neusanjeev,
    neusanjeev said:
    .... can we have any method so that we can read from that byte and can know , is it daily or weekly, or monthly etc
    At that moment we have not such method, but maybe you could try to get this information through:
    DateRecurrence rec = ultraCalendarInfo1.Appointments[0].Recurrence;
    or another approach could be if you handle:
    private void ultraCalendarInfo1_BeforeDisplayAppointmentDialog(object sender, DisplayAppointmentDialogEventArgs e)
         DateRecurrence rec = e.Appointment.RecurringAppointmentRoot.Recurrence;
    Regards
