1225
Grid Layout changes
I have a grid which is bound to an UltraDataSource.  If I leave the form open in design mode and start debugging, when I exit the debug session the layout is missing visually.  Additionally, although it is set to SingleBand, there is a second band when I I click on the ultraGrid Designer.
If I close the form before starting to debug the problem does not occur.
This odd behavior occurs even after I commented out the entire Load event - so none of my  code executed
