760
Exception When Setting The TopNode Property
I set the TopNode property on the a tree that I rebuild to get the tree to remember the state it was left before I rebuilt it. Setting the TopNode property seems to work almost all the time but every once in a while I will get the following exception described below.
"All parent nodes must be expanded when setting 'TopNode'."
Im confused as to why this error is throw. It seems to have a valid TopNode and that the node is expanded. Any insight would be much appreciated. Thank you!
