As the attached picture, the merge style is Always, on the column Contact Name, the two cells of "Janine Labrune" are combined, who to split them?
Requirement rule: if the cell value on the prior column (here the column City) is different, then the cells on the latter column (here the column Contact Name) will not be combined. Mambe there shouble be an event or something similar to inject such logic code.
Is it possible?
It now works for this requirement.
I am just checking about the progress of this issue. Let me know If you need any further assistance on this matter?
Hello ,
This issue was already discussed and you could review the discussion on the following link:
http://ko.infragistics.com/community/forums/t/44319.aspx
Also you will find there and a small sample.
