When I save my calendar XML using the infra API using the following code line,
this.ultraCalendarInfo1.SaveAsXml(fileName, CalendarInfoCategories.All);
I get this exception
dateTimeInvalidLocalFormat Exception
"A UTC DateTime is being converted to text in a format that is only correct for local times. This can happen when calling DateTime.ToString using the 'z' format specifier, which will include a local time zone offset in the output. In that case, either use the 'Z' format specifier, which designates a UTC time, or use the 'o' format string, which is the recommended way to persist a DateTime in text. This can also occur when passing a DateTime to be serialized by XmlConvert or DataSet. If using XmlConvert.ToString, pass in XmlDateTimeSerializationMode.RoundtripKind to serialize correctly. If using DataSet, set the DateTimeMode on the DataColumn object to DataSetDateTime.Utc."
The reason for posting here was that if someone from our peers have encountered this problem before he/she
can help me. Let me try this Developer Support option also.
This is a per-to-peer forum. You should report issues like this one to Developer Support so that you can provide the details necessary in order to reproduce the problem, for example the locale settings.
