Hi
Please see the image and cs code file.
formula for column RATE: if( [TOTAL] <>0 , [FAIL] / [TOTAL], dbnull() )formula for summary of column RATE : if( [TOTAL()] <>0 , [FAIL()] / [TOTAL()], dbnull() )summary type for column NG_KG is sum.
The first image works properly with the original value in the grid, but when the value on the cell (column NG_KG) in modified from 45 to 60, the summary value on the column RATE also changes strangely.
Is it a bug?
Hello Felix,
CAS-98958-L6M9Y4 has been created for this issue. I have logged this issue with our developers and will provide additional details via the case. I will post again here when the issue has been resolved.
OK, hope it will be fixed in the near future.
Okay, that's what I wanted to confirm.
This appears to be a bug in the controls. So I'm going to forward this thread over to Infragistics Developer Support and ask them to create a case for you and write this up as a bug for developer review.
As you can see,the formulas in the attached project source code, there is nothing connection between the column/summary NG_KG and RATE and I do NOT want such connection (also NOT my expecting), just the UltraGrid calculates the wrong smuarry value as I described in the last post.
You seem to have simply re-iterated your description of the problem here without answering my question. I understand all of that, already.
The question I am asking is...
Is there some connection in your application between the NG_KG summary and the Rate summary that I am not seeing?
It seems to me that the NG_KG summary should have NO effect on the Rate summary at all. Is that correct. I just want to confirm that that is the behavior you are expecting.
