425
ValueList in Grid DropDownList - unable to convert string to int
Banging my head against the wall on this one - I have to be missing something obvious but cannot see it.
I'm using ValueList on two columns in a UltraWinGrid with the Column Style set to DropDownList.  The bound table for these columns/fields is Int32.  I am creating the value list from an enumeration, but have also tried a simple ValueList.Add(1,Some Item Description) and get the same results.  Any time I select an item from the list it gives me the error Unable to convert from System.String to System.Int32.  It appears to think that the DropDownList data is string instead of integer.  I've tried explicitly declaring as int by using ValueList.Add(CInt(myvalue),Some Text...) but this doesn't work either.  If I change the bound table column data type to string then the e.Cell.Value (on AfterCellUpdate) gives me the list display value.  So it appears that it's binding to the display/text value rather than to the integer value, but I'm not sure where to change this (I did find the ValueList.DisplayStyle property and set it to DisplayText) but this hasn't had any effect.
I'm sure this is something simple that I've been starting at too long to see!
