how can I turn off the display of the time in an Appointment in an UltraDayView?
Thank you in advance
The following KB article demonstrates the opposite, that is, how to always display the times, but the approach would be the same.
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=7316
Note that this article predates the Office2007 ViewStyle support that was eventually added, so it will not work for that ViewStyle without modifications.
Hi. I have the same problem however I want to display the start and endtime no matter when the appointment starts or ends.
At the moment when I have set TimeSlotInterval to 30 minutes and I have an appointment starting 15:00 and ending 20:00 no times are displayed inside the appointment.
If my Appointment would end 20:15 I would see the start and endtime.
Is there some option to disable this behaviour?
Best regards,
sheitman
Hi
-> Change the Subject property of the Appointment object. Else provide a bit details of your question?
I already changed the Subject, but if the Appointment does not fit exactly into a timeslot it automaticly displays the exact time. How can I turn this off?
