I was wondering if there was a way to enable column deletion through drag&drop ? This is similar to Outlook 2007, when the user clicks and drags a column header some place other than the band header area.
Andrew
Hi Andrew,
No. There's a BeforeColPosChange and AfterColPosChanged event, but these events do not fire until after the drop operation is completed.
Thanks Mike,
Is there an event that fires when the column header is dragging ?
No, you should Submit a feature request to Infragistics.
