1590
Continuous cell click event
I am unable to get the event of value change over continuous clicking in active cell. Below is what i am doing:
I have set the data type of the cell to boolean, and style as check box. Now when user continuously click on the cell, once its activated, i am unable to get the updated value of cell after each click. I have tried the following events but each got issues with it.
_AfterCellUpdate: This event will fire after the cell will lost focus, but in my case it is not
_BeforeCellUpdate: This event will also fire after the cell will lost focus, but in my case it is not
_CellClick: This method is continuously showing me the value as False
_CellChange: Again this method is continuously showing me the value as False
So please help me to find an event which will give me the proper value against each click. Or way out.
Thanks.
  • 48586
    Verified Answer
    Hello ,
    What you could do in your case is it handle CellChange event of UltraGrid and to check CheckedState of the EditorResolved property of the cell. If we assume that your check box column is named “Bool”, the you could use code like this below in the  CellChange event of UltraGrid:
    if (e.Cell.Column.Key == "Bool")
                        //check CheckState to determine the new value of the editor
                    Debug.WriteLine(((CheckEditor)e.Cell.EditorResolved).CheckState);
    Please see attached sample where I have implemented my suggestion.
    99315.zip
