I'm using a WinCombobox which has a list of Strings as datasource.
So after construction of the combo, it contains multiple items (strings). Now I want the user to allow adding entering a new value which is not listed in the combo.
This value must NOT be added to the combolist after entering.
Which properties do I have to set to make this work ?
Sorry, problem is solved. I forgot the LimitToList-property.
Hello timdelma,
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
After reading your post several times, what I understood is - you want to allow the user to add a new value which is not listed in the combo, but this value must not be added to the combo. Where do you want to add it then? And do you want to add it at all anywhere? If you mean that you cannot enter a value which is not in the list, I suppose that you have changed the DropDownStyle or the LimitToList properties.
Please make sure that they are set as follows:
ultraCombo1.DropDownStyle = Infragistics.Win.UltraWinGrid.UltraComboStyle.DropDownList;
ultraCombo1.LimitToList = true;
Please feel free to let me know if I misunderstood you or if you have any other questions.
