4341
Display exponential value on X axis.
Hello Support,
We are using V10.3 WinChart control in our applicaiton. We want to display exponential values on the X axis i.e. say if the value on X axis is 833333 then we need to display the value as 8.33E+05. Is there any property or any other way to display exponential values on the X axis of the chart control. Looking forward to your reply.
  • 53790
    At that moment we have not such property, but maybe one possible approach to acheive desired result could be :
    private void ultraChart1_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e)
                foreach (Primitive pr in e.SceneGraph)
                    if (pr.GetType() == typeof(Text) && ((Text)pr).Row != -1 && ((Text)pr).Column != -1)
                            decimal d = Convert.ToDecimal( ((Text)pr).GetTextString());
                            ((Text)pr).SetTextString(String.Format("{0:e}", d));
                            ((Text)pr).PE.Fill = Color.Red;
