I'm trying to avoid users to press "ENTER" each time a UltraMessageBox appears. I need to force them to use the mouse to close the message box (or to click on any of the buttons) due to new company policy (sometimes people don't read the messages and just press "Enter" without knowing what they're doing).
How can I implement this?
Hi rmeleiro,
If you have any further questions regarding this behavior, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
Although this behavior is not supported by the MessageBox, as neither the ultraMessageBoxManager1 or the .Net MessageBox extend event handlers for detecting input from the user and those available by the main form are not accessible as only the modal dialog will have focus when it is displayed; it should be possible to handle this behavior by creating your own custom modal MessageBox from a discrete form.
Using this approach, you will have access to the specific event handlers necessary for metering interactions with the MessageBox.
If you have any further questions, please let me know.
