1369
Change Row# Label on Column chart
This is what I am doing.
DataTable dtTable = new DataTable();
DataColumn dcCol = new DataColumn("INV", typeof(decimal));
dtTable.Columns.Add(dcCol);
dcCol = new DataColumn("JOB", typeof(decimal));
dcCol = new DataColumn("PCD", typeof(decimal));
DataRow drRow = dtTable.NewRow();
drRow[0] = 100;
drRow[1] = 150;
drRow[2] = 75;
dtTable.Rows.Add(drRow);
drRow[0] = 200;
drRow[1] = 50;
drRow[2] = 100;
drRow[0] = 100;
drRow[1] = 150;
drRow[2] = 75;
ultraChart.DataSource = dtTable;
ultraChart.DataBind();
This produces three values in a series and uses the column name as labels for each column within a series.  I have tried using IRenderLabel, which is how I am labeling the Y axis values, to achieve the desired result.  It displays in the bottom of each series Row#0, Row#1, Row#2.  How can I change this?  IRenderLabel changes my column names and I want to be able to keep those as assigned to the datatable.  Thanks for the help.
Kashif
