I am using an UltraCalendarCombo with a MinDate set to Date.Now. If I try to select yesterday though, the UltraCalendarCombo is set to "(none)." This occurs even if I have the AllowNull property set to false.
Edit: Setting the mindate to Date.Now also disables today as well as the previous dates. It is when I try to select today that the UltraCalendarCombo display text is being set to "(none)" and the value is being set to String.Empty. This occurs even if the property AllowNull is set to false.
I am having a similar problem. With AllowNull = False a user can clear the date with the keyboard then click in the calendar and then out of the control without picking a date and it allows the date to be saved as null. Is this a known bug with AllowNull?
Sara Burns
ICCO
Hello Bryan,
I created the following case for you: 'CAS-100914-Y9Y7P1' and will update you through it.
I'm just not sure I understand the need for handling partially past dates differently from past dates. The partially past date is denied which prevents the user from setting the UltraCalendarCombo to that date. If the user isn't allowed to set their UltraCalendarCombo to that date, then I believe it should be handled the same as the other dates that are denied.
Admittedly, just because I can't think of a reason for this behavior, doesn't mean there isn't one. This is simply my opinion.
It is a reasonable question and after some research I think that is made because there should be a way to distinguish the different states in the calendar - past(denied, future(allowed), partially past(denied). If you think that this should be handled in another way, I could start researching a workaround and/or contact our engineering staff to review this behavior.
This fixes my issue, thank you.
Out of curiousity, since DateTime.Now is being counted as a past day, shouldn't it be handled the same as the other past days instead of setting the UltraCalendarCombo value to String.Empty, or is there a reason for this?
