685
getting value of any column in a dropdown when it is in a grid.
The following code works  (dropdown in a grid), but I am after a better way.
Without using  'value member' or the 'display member', how can i get the same result by referencing the grid and dropdown indirectly???
private void ultraGrid1_CellListSelect(object sender, CellEventArgs e)
if ("TaskID".Equals(e.Cell.Column.Key))
Infragistics.Win.UltraWinGrid.UltraGridRow currentRowView = (Infragistics.Win.UltraWinGrid.UltraGridRow)ultraGrid1.DisplayLayout.ActiveRow;
Console.WriteLine(e.Cell.Row.Cells["TaskID"].Value);
 Infragistics.Win.UltraWinGrid.UltraDropDown myctrl = this.ultraDropDownTask;
myctrl.ActiveRow.Cells["Whom"].Value.ToString() ;
This gets the value, but is it possible to use currentRowView.?.?.?.?.value???
  • 71886
    Hello buckland,
    You could try the code sample I prepared for you:
     private void ultraGrid1_CellListSelect(object sender, Infragistics.Win.UltraWinGrid.CellEventArgs e)
                UltraDropDown drop = (UltraDropDown)e.Cell.ValueListResolved;
                Console.WriteLine(drop.DisplayLayout.ActiveRow.Cells["Column 1"].Value.ToString());
    Please review the above code to see if it meets your requirements and feel free to let me know if I misunderstood you or if you have any other questions.
