Hi
How can i hide the group header on the ultraExplorebar....?? Iam looking at the functionality of OUTLOOK 2010.
I want to hide the header but still have the group selectable in the control...?? any ideas?
So far so good Boris thanks... Its easier to mimic the outlook 2007 behaviour that the outlook 2010...
Ill let you know if i have any more issues
thanks
Hello Burmo,
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
I am ready to help you with these requirements, it is just that I am not sure what you want exactly here. Could you please provide a picture(screenshot) with explanations - what you want, how and where exactly.
Thank you in advance.
Hi Boris
After review this a few times what i wanted was not going to work out...
what i need to do now is the following:
1) change the text in the group header
2) set the height of the group header
3) make the group header blend in with its container control... (there should be no distinction between the group header and the contanier control if a treeview is been used as the control container - the group header and the container control must look as 1 component or object when the application is run...)
Im sorry for the inconvenience... any suggestions or code samples will be appreciated....
Then you could use instead:
parent.Parent.Rect = new Rectangle(0, 0, 0, 0);
Please note that using this method with CreationFilter you would have to handle all elements' resizing, moving, etc.
