I am using ultradocManager control for creating docable panels. The docable panels showing right side from the starting point of the form. in my form have one panel with dock as top. so i need to show the docable panels after the panel space in right side.
Here is the sample:
Hello Vinod,
One possible approach to achieve desired behavior could be if you are using Container Control. Please take a look at the attached sample for more details and let me know if you have any questions.
Regards
hi,
we create docable panel and make doc area pane's dock as right direction, the docable panel will attach to top right cornner of the form . in my form i have a panel at top of the form, the docable panel should attach below the panel in the right side. Means the docable panel should be pinned after the panel space from the top.
Hi Vinod,
I suppose that this thread is similar with another forum thread http://ko.infragistics.com/community/forums/p/74413/376352.aspx
Please take a look there and let me know if you have any questions.
