2945
UltraTextEditor with dropdown
I'm building a multi-select dropdown using an UltraTextEditor and an UltraGrid as my EditorButtonDropdown control.  All works pretty well, but I want my dropdown to have the behaviour of a DropDownList, i.e. no editing in the textbox.
I've set the ReadOnly property to True, but unfortunately I still have a cursor in the text box.
I also want the grid to dropdown whenever I click on the text box.  I can use the AfterEnterEditMode event to force a DropDown which works ok, however, when the control Closes Up, the textbox is still in Edit Mode, so I can't repeat the trick.
So, (1) is there a way to prevent the cursor?  I tried cancelling the control going into edit mode in the BeforeEnterEditMode event, however, this prevents me being able to dropdown the grid.
And (2), is there any way to programatically exit from Edit Mode?
Campbell
