We have a multilingual application using 10.2 with ampersand + shortcut characters in the menus. In Russian only, the alt key must be pressed simultaneously with the shortcut key to activate the menu choice. In other langauages such as French and German, the alt key is 'sticky' so that 2 successive keystrokes activate the desired menu. In all cases, the keyboard input in Windows is set to the appropriate native language to use the native keyboard. Is there any way we can make the Russian menu shortcuts work like other languages?
Hello Wally,
I created the following case for you: CAS-102416-H3Y0H4 and will update you through it.
It seems that the issue here is that your version of 10.2 is trial and this is the reason you cannot see the service releases.
Hello Boris,
When I follow those instructions, the only service releases I see for win forms are 11.2, 12.1, and 12.2. No 10.2 is visible to me. The heading notes that only the past 3 releases are available for each product as service releases.
Wally
If you have a key for 10.2 you should be able to see the mentioned version in https://ko.infragistics.com/my-account/keys-and-downloads/, then Keys & Downloads on the left, when loaded, please select v10.2 from the Table at the center and then click on 'Service Releases' below, you should then have NetAdvantage for Windows Forms 2010 Vol. 2 - Windows Forms Service Release.
Please do not hesitate to ask if something comes up.
I am not able to locate the version you reference. I have latest from mykeys and downloads - is 10.2.20102. Can you give me a link or otherwise direct me to the version 10.2.2151?
