2265
Entity Framework Multiple Band Issue with Parent/Child relationships
I am binding my UltraGrid to an Entity Framework (nHydrate) data source (System.Windows.Forms.BindingSource).  So for examples sake:
ClassA (Band 0)
    ClassB (Band 1)
I can add rows to Band 0 without any problems using the Fixed Header Row.  I am using the AllowAddNew = FixedAddRowOnTop to do this.  I am doing the same with Band 1.
However, when I add a new row in Band 1, a new instance of ClassB is created which I can see in the AfterRowUpdate event.  However, the relation between ClassA and ClassB is never set and if I try to save the context I get the error:
The operation failed: The relationship could not be changed because one or more of the foreign-key properties is non-nullable. When a change is made to a relationship, the related foreign-key property is set to a null value. If the foreign-key does not support null values, a new relationship must be defined, the foreign-key property must be assigned another non-null value, or the unrelated object must be deleted.
If I manually try to set the relationship either by adding CType(e.Row.ParentRow.ListObject, ClassA).ClassB.ToList().Add(<the new ClassB row> ), then I get an extra row in the grid in Band 1.
This is frustrating me as I have spent a lot of late nights trying to work around this.  I cannot see any way to proceed with the grid - I hope I am wrong.
Any thoughts?
Andez
