695
Enter act like Tab in UltraGrid -> Need to move to same column + Next row when pressing enter which is in edit mode. How ?
The below articile helped me which explains about Enter key act like Tab.
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2028
But as per my requirement, I have to move to the same column in the Next row when the enter key is pressed. The column data is in edit mode. How will i achieve this functionality.
Gudi
  • 71886
    Hello Gudi,
    Please try the following code:
    private void ultraGrid1_KeyDown(object sender, KeyEventArgs e)
    UltraGridCell oldIndex = null;
    switch (e.KeyCode)
    case Keys.Enter:
    oldIndex = ultraGrid1.ActiveCell;
    ultraGrid1.PerformAction(UltraGridAction.ExitEditMode, false, false);
    ultraGrid1.PerformAction(UltraGridAction.BelowRow, false, false);
    ultraGrid1.ActiveCell = ultraGrid1.ActiveRow.Cells[oldIndex.Column];
    e.Handled = true;
    ultraGrid1.PerformAction(UltraGridAction.EnterEditMode, false, false);
    break;
    I wrote about the same thing a day ago in the following forum thread, it might be helpful to you:
    http://ko.infragistics.com/community/forums/p/54541/377015.aspx#377015
