I'm really sorry if my problem was discussed already. But i did not found an answer.
I have ultragrid which is bound to DataTable. One of the columns should support masked input, this datacolunm is type of string.
Entered data should have format "aaaaa/aa.aaaa", where 'a' is alphanumeric.
Here is short code example.
column.EditorComponent = new UltraMaskedEdit() { InputMask = "aaaaa\\/aa\\.aaaa", DisplayMode = MaskMode.IncludeBoth, ClipMode = MaskMode.IncludeBoth };
When the cell is in edit mode mask is shown. When the cell is not active - data are shown without mask. I've tried to set column.Format to "aaaaa\\/aa\\.aaaa", but unsuccessful.
If I do not set EditorComponent, but use column.MaskInput instead, then data from cell are stored with mask into DataTable.
Setting column.MaskDataMode to MaskMode.Raw has np effect.
Please help me to show my data with mask :)
You need to use the EditorButtonClick event on the UltraTextEditor, not the click event of the button.
The e.Context parameter in the event will give you the cell for which the button was clicked.
Hi Mike ..
As i am new to this Infragistic, so biothering you repeateadly.. Sorry for the same.
Facing new issue with UltraGrid.
Steps:
Run Time i added one more column to one grid.
created one UltraTExtEditorControl with button left on it and assigned the previously added column editor component as UltraText Editor.
Now whole cell for that column is appearing as UltraTextEditor with button but click event of that button is not getting fired.
Please let me know the if im missing some step.
Thanks..
Hi Mike..
The problem has been solved by using DataSourceUpdateMode to OnValidation.
However i am still trying to understand why that problem was coming i was using DataSourceUpdateMode to OnPropertyChanged while binding property with it.
Rajeev Ranjan
Hi Mike.
I am facing very strange problem in my current application.
I am showing one form as modal window .In that window, at run time i m adding DateTime editor control and code for the mentioned points is like :
private
Control[] SetTheDateTimeBasedControl()
//Minimum date value control...
var udteMinDateValue = new UltraDateTimeEditor
FormatProvider =
new System.Globalization.CultureInfo("fr-FR"),
FormatString =
"dd/MM/yyyy hh:mm:ss",
MaskInput =
"dd/mm/yyyy hh:mm:ss",
Location = _minLoc,
Name =
"udteMinDateValue",
Tag =
"Removable Control",
NullText =
"Select begin date",
Size = _size,
TabIndex = 7,
Value =
null
//Maximum Date based control..
var udteMaxDateValue = new UltraDateTimeEditor
Location = _maxLoc,
"udteMaxDateValue",
"Select end date",
TabIndex = 8,
//Adding control to the list..
_controlList.Add(udteMinDateValue);
_controlList.Add(udteMaxDateValue);
return _controlList.ToArray();
For only date data type
same as above except
"dd/mm/yyyy",
When i am running my application, not able to change year part in case of date Data Type.
In case DateTime Data Type not able to enter hh mm and sec more than 02..
Not able to find what can be the possible cause..
Please reply me at the earliest...
The only thing was missing in my code was UseEditorMask property of the column which i needed to set to true.
Sorry for the late update.
Thanks a lot for your concern.
