530
Visual enhancement for row drag and drop
Hi, I'm trying to implement row drag and drop on a UltraGrid and I think I got some of it to work by looking at the example on your knowledge base, but I would like to apply some highlighting between the rows where the selected rows would be dropped, or something like when we move column around and have arrows pointing to where the new column would be placed. Any suggestions to how to get this implemented?
  • 469350
    There's no easy way to do this.
    There's a sample for the UltraWinTree which draws drop indicators on the tree using a DrawFilter, so you could probably adapt that sample for use in the grid. But it will not be a trivial task, so I wouldn't recommend it unless you can commit a lot of time to it.
    The sample I am referring to is:
    ...\2012.1\Samples\WinTree\CS\UltraTree Drag and Drop CS
    or
    ...\2012.1\Samples\WinTree\VB\UltraTree Drag and Drop VB
