When run our application and we could get following exception some times, could you please have a look at this?
System.Security.SecurityException: Request for the permission of type 'System.Security.Permissions.UIPermission, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' failed. at System.Security.CodeAccessSecurityEngine.ThrowSecurityException(Assembly asm, PermissionSet granted, PermissionSet refused, RuntimeMethodHandle rmh, SecurityAction action, Object demand, IPermission permThatFailed) at System.Security.CodeAccessSecurityEngine.ThrowSecurityException(Object assemblyOrString, PermissionSet granted, PermissionSet refused, RuntimeMethodHandle rmh, SecurityAction action, Object demand, IPermission permThatFailed) at System.Security.CodeAccessSecurityEngine.CheckHelper(PermissionSet grantedSet, PermissionSet refusedSet, CodeAccessPermission demand, PermissionToken permToken, RuntimeMethodHandle rmh, Object assemblyOrString, SecurityAction action, Boolean throwException) at System.Security.CodeAccessSecurityEngine.CheckHelper(CompressedStack cs, PermissionSet grantedSet, PermissionSet refusedSet, CodeAccessPermission demand, PermissionToken permToken, RuntimeMethodHandle rmh, Assembly asm, SecurityAction action) at System.Security.CodeAccessSecurityEngine.Check(Object demand, StackCrawlMark& stackMark, Boolean isPermSet) at System.Security.CodeAccessPermission.Demand() at System.Windows.Forms.Control.get_Parent() at Infragistics.Win.IGPanel.PaintTransparentBackground(Graphics g, Rectangle clipRectangle) at Infragistics.Win.Misc.UltraExpandableGroupBoxPanel.PaintBackground(PaintEventArgs e) at Infragistics.Win.Misc.UltraExpandableGroupBoxPanel.OnPaintBackground(PaintEventArgs e) at System.Windows.Forms.Control.PaintTransparentBackground(PaintEventArgs e, Rectangle rectangle, Region transparentRegion) at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle, Color backColor, Point scrollOffset) at System.Windows.Forms.Control.PaintBackground(PaintEventArgs e, Rectangle rectangle) at System.Windows.Forms.Control.OnPaintBackground(PaintEventArgs pevent) at System.Windows.Forms.ScrollableControl.OnPaintBackground(PaintEventArgs e) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs) at System.Windows.Forms.Control.WmEraseBkgnd(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)The action that failed was:DemandThe type of the first permission that failed was:System.Security.Permissions.UIPermission
Hi Chance,
Do you manage to solve this issue. If you have any furthered questions please let us know.
At first look this seems issue with application or Infragistics assemblies are not full trusted. Can you please give us more information, how you deploy your application, which Infragistics version you are using, Framework version, how and under what you are running the application. Since I believe that this is not local installation and run locally?
