405
Change names of properties in formula builder
Hi
I'm busy building a very generic data structure where the column names on a grid are Text1, Text2....; Numeric1, Numeric2..... and so on. The user has the ability to rename the columns to something more meaningful. I've also given the user the ability to create a new column using the formula builder. When the formula build opens it displays to columns as Text1, Text2.... and not as the renamed columns.
Is there a way to get the formula builder to display the meaningful column (Column Header) name in the formula builder instead of the column key?
