Hi.
I create an ultrachart and then call the RenderPDFFriendlyGraphics function to render the chart to a pdf report. The code looks like this:
ICanvas canvas = newFlow.AddCanvas();
canvas.Width = new FixedWidth(210);
canvas.Height = new FixedHeight(170);
Graphics g = canvas.CreateGraphics();
ultraChart1.RenderPdfFriendlyGraphics(g);
The RenderPDFFriendlyGraphics takes a long time to execute. Is this normal? My chart consists of about 50 series each of 175 points.
Sorry for the delay but I found the cause of the issue and it is currently being verified and if all goes well a fix will be available in the next Service Release. Let me know if you see anything else performance related to the chart -> pdf process but I think you'll be pleasantly surprised by the speed of the process now.
Hello Sudnya,
I've submitted this issue to our engineers for them to research. I've created a private support case so you can be notified of the results of their research.
Hi Dave.
Thats what we currently do in the application. However, when the bitmap is plotted on a PDF and the document is zoomed the bitmap loses its resolution and looks grainy. This was the reason I was exploring other options and came across the RenderPDFFriendlyGraphics function.
So using the bitmap is not really an option.
It might be more feasible for you to call DrawToBitmap() and then insert that bitmap into the document.
OK. I am working with medical software and this will be the minimum amount of data I am plotting per graph. Plus I am plotting 6 such graphs.
So that probably means using the infragistics chart in this situation is not going to deliver the results in a resonable amount of time. Do you have any other suggestions as to what I can use.
Thanks.
Sudnya
