885
Read Cells From UltraCombo.SelectedRow Editor Component At Initialization
I have a grid column with an UltraCombo as the editor component.
The UltraCombo translates a stored ID into a human readable description.
I would like to read ActivitiesUltraDropDown.SelectedRow.Cells(2).Value and put that into an unbound column in the grid. I can make this work on the TextChanged event of the UltraCombo, but that event won't fire unless the user makes a change to the UltraCombo. I need an event to do this during grid load when the data is just loading, not changing.
I need a clue as to which event I could use when;
  • the data is all loaded into the grid (underlying ID's)
  • the UltraCombo has positioned itself on its row corresponding to the ID
  • each row in the UltraGrid is being iteratively selected
