Can someone redirect me to an appropriate content where i can build my paging control for wingrid ? I'm using Infragistics WinForms Ultimate 2011.
Hello viswanth,
viswanth said: Is there any other option to get paging going other than custom stuff ?
viswanth said: Seems like i'm using an older version
Regards
Seems like i'm using an older version. Is there any other option to get paging going other than custom stuff ?
Hello Viswanth,
Have you been able to resolve your issue ? Did you have a time to take a look at the attached projects.If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
Please take a look at the attached file. I already build both solutions with your version. In the folder UltraGridPaging you could find the project that will create your DLL file. In the folder UltraGridPagingSample you will find the test sample where I`m using this assembly.
Please let me know if you have any qestions
It is 11.1.20111.1003. If not possible please redirect me to the resource(s) where i can build paging.
Thanks !
