180
ultragrid formula performance
Hello Support Team,
Here I met a performance problem while using formula in ultragrid. I have around 50,000 data entries (each entry with more than 200 fields) populated in an grid it takes around 20 min including query, download, populating data to grid. in the testing I noticed around 60% of the time was in the formula assignment clause.
the grid data populating business is:
1. fill data in grid
2. set formula (column.Formula = translatedFormula;)
3. set format
can you please help to see if there is any solution to improve the populating data performance? thank you in advance.
