2145
Exclude from column chooser appears not to work correctly.
Hi All,
Normally I don't have an issue with this but it appears not respect the option in the following situation.
When I load a layout in it may be from a previous version where the column was once visible. So what I do once the layout and datasource is assigned I loop through and hide/exclude certain columns after the layout is loaded which is after the datasource is assigned. Although it respects the hidden property it does not respect the ExcludeFromColumnChooser property. Is there something I am missing? Is there a refresh column chooser or something I need to call to make the grid respect it?
I know there was an issue in 2009? But I am on 12.2, so I thought that bug was fixed?
Alex
