105
DataBind on WinGrid dose not refresh child bands
hi,
Im binding the grid to a business object witch contain a list of other object (like defined in the code below)
Im currently updating the list of sub objects and their properties and call the grid DataBind in order to update the display
but the grid dose not update the display and even dose not call the InitializeRow event
the only "ugly" way i found to refresh the display is by calling the code as i wrote in button2_Click handler below
the problem with this way to refresh the grid is that all the expended nodes will collapse
is this a problem in DataBind method or am i doin somthing wrong?
this is a simple tester i wrote to recreate the problem.
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace TestBind
    public partial class Form1 : Form
        private List<Moo> moos;
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            moos = new List<Moo>();
            moos.Add(new Moo("yoyoyo"));
            mooBindingSource.DataSource = moos;
        private void button1_Click(object sender, EventArgs e)
            moos[0].Moos.Add(new SubMoo("asdasd"));
            ultraGrid1.DataBind();
        private void button2_Click(object sender, EventArgs e)
            mooBindingSource.DataSource = typeof(Moo);
    public class Moo
        private List<SubMoo> moos;
        private string name;
        public Moo(string name)
            this.name = name;
            moos = new List<SubMoo>();
        public string Name
            get { return name; }
        public List<SubMoo> Moos
            get { return moos; }
    public class SubMoo
        public SubMoo(string name)
            this.name = name;
        public string Name
thanks, moshe
